RTEMS Logo
RTEMS 4.6.0 On-Line Library
Miscellaneous Support Files bsp_cleanup() - Cleanup the Hardware
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
5.8: bsp_cleanup() - Cleanup the Hardware
The bsp_cleanup() is the last C code invoked. Most of the BSPs use the same shared version of bsp_cleanup() that does nothing. This implementation is located in the following file:
c/src/lib/libbsp/shared/bspclean.c
The bsp_cleanup() routine can be used to return to a ROM monitor, insure that interrupt sources are disabled, etc.. This routine is the last place to insure a clean shutdown of the hardware.
