OAR
RTEMS 4.5.0 On-Line Library
Apply RTEMS Patch to GNAT
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
3.9: Apply RTEMS Patch to GNAT
Apply the patch using the following command sequence:
cd tools/gnat-3.12p-src
zcat ../../archive/gnat-3.12p-rtems-20000429.diff.gz | patch -p1
Check to see if any of these patches have been rejected using the following sequence:
find . -name "*.rej" -print
If any files are found with the .rej extension, a patch has been rejected. This should not happen with a good patch file which is properly applied.
