OAR
RTEMS 4.5.0 On-Line Library
Building the GNAT Cross Compiler Toolset
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
Chapter 3: Building the GNAT Cross Compiler Toolset
  • Create the Archive and Build Directories
  • Get All the Pieces
  • Unarchiving the Tools
  • Host Specific Notes
  • Reading the Tools Documentation
  • Apply RTEMS Patch to GCC
  • Apply RTEMS Patch to binutils
  • Apply RTEMS Patch to newlib
  • Apply RTEMS Patch to GNAT
  • Copy the ada Subdirectory to the GCC Source Tree
  • Localizing the Configuration
  • Running the bit_ada Script
  • Common Problems
  • This chapter describes the steps required to acquire the source code for a GNU cross compiler toolset, apply any required RTEMS specific patches, compile that toolset and install it.
