OAR
RTEMS 4.5.0 On-Line Library
Learn about the network device
PREV UP NEXT Bookshelf RTEMS Network Supplement
2.2: Learn about the network device
Before starting to write the network driver become completely familiar with the programmer's view of the device. The following points list some of the details of the device that must be understood before a driver can be written.
In addition, some controllers have specific questions regarding board specific configuration. For example, the SONIC Ethernet controller has a very configurable data bus interface. It can even be configured for sixteen and thirty-two bit data buses. This type of information should be obtained from the board vendor.
