This chapter is intended to provide an introduction to the
procedure for writing RTEMS network device drivers.
The example code is taken from the `Generic 68360' network device
driver. The source code for this driver is located in the
c/src/lib/libbsp/m68k/gen68360/network
directory in the RTEMS
source code distribution. Having a copy of this driver at
hand when reading the following notes will help significantly.
