OAR
RTEMS 4.5.0 On-Line Library
Timer Manager Timer Service Routines
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.2.3: Timer Service Routines
The timer service routine should adhere to C calling conventions and have a prototype similar to the following:
rtems_timer_service_routine user_routine(
  rtems_id   timer_id,
  void      *user_data
Where the timer_id parameter is the RTEMS object ID of the timer which is being fired and user_data is a pointer to user-defined information which may be utilized by the timer service routine. The argument user_data may be NULL.
