OAR
RTEMS 4.5.0 On-Line Library
Task Manager Notepad Locations
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.3.8: Notepad Locations
RTEMS provides sixteen notepad locations for each task. Each notepad location may contain a note consisting of four bytes of information. RTEMS provides two directives, rtems_task_set_note and rtems_task_get_note, that enable a user to access and change the notepad locations. The rtems_task_set_note directive enables the user to set a task's notepad entry to a specified note. The rtems_task_get_note directive allows the user to obtain the note contained in any one of the sixteen notepads of a specified task.
