OAR
RTEMS 4.5.0 On-Line Library
Task Manager Changing Task Mode
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.3.7: Changing Task Mode
The rtems_task_mode directive is used to obtain or change the current execution mode of the calling task. A task's execution mode is used to enable preemption, timeslicing, ASR processing, and to set the task's interrupt level.
The rtems_task_restart directive resets the mode of a task to its original value.
