OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_LOOKUP_NAME - Lookup a device
16.4.3: IO_LOOKUP_NAME - Lookup a device
CALLING SEQUENCE:
procedure IO_Lookup_Name (
   Device_Info  :    out RTEMS.Driver_Name_t;
   Result       :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.UNSATISFIED - name not registered
DESCRIPTION:
This directive returns the major/minor number pair associated with the given device name in device_info.
NOTES:
This directive will not cause the calling task to be preempted.
