OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_REGISTER_NAME - Register a device
16.4.2: IO_REGISTER_NAME - Register a device
CALLING SEQUENCE:
procedure IO_Register_Name (
   Major  : in     RTEMS.Device_Major_Number;
   Minor  : in     RTEMS.Device_Minor_Number;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.TOO_MANY - too many devices registered
DESCRIPTION:
This directive associates name with the specified major/minor number pair.
NOTES:
This directive will not cause the calling task to be preempted.
