OAR
RTEMS 4.5.0 On-Line Library
Region Manager Acquiring a Segment
14.3.4: Acquiring a Segment
The rtems.region_get_segment directive attempts to acquire a segment from a specified region. If the region has enough available free memory, then a segment is returned successfully to the caller. When the segment cannot be allocated, one of the following situations applies:
If the task waits for the segment, then it is placed in the region's task wait queue in either FIFO or task priority order. All tasks waiting on a region are returned an error when the message queue is deleted.
