The rtems.region_extend
directive may be used to add memory
to an existing region. The caller specifies the size in bytes
and starting address of the memory being added.
NOTE: Please see the release notes or RTEMS source code for information regarding restrictions on the location of the memory being added in relation to memory already in the region.
