OAR
RTEMS 4.5.0 On-Line Library
Event Manager Determining the Pending Event Set
11.3.3: Determining the Pending Event Set
A task can determine the pending event set by calling the rtems.event_receive directive with a value of RTEMS.PENDING_EVENTS for the input event condition. The pending events are returned to the calling task but the event set is left unaltered.
