OAR
RTEMS 4.5.0 On-Line Library
Event Manager Receiving an Event Set
11.3.2: Receiving an Event Set
The rtems.event_receive directive is used by tasks to accept a specific input event condition. The task also specifies whether the request is satisfied when all requested events are available or any single requested event is available. If the requested event condition is satisfied by pending events, then a successful return code and the satisfying event set are returned immediately. If the condition is not satisfied, then one of the following situations applies:
