OAR
RTEMS 4.5.0 On-Line Library
Interrupt Manager INTERRUPT_ENABLE - Enable Interrupts
6.4.3: INTERRUPT_ENABLE - Enable Interrupts
CALLING SEQUENCE:
procedure Interrupt_Enable (
   Level : in     RTEMS.ISR_Level
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive enables maskable interrupts to the level which was returned by a previous call to rtems.interrupt_disable. Immediately prior to invoking this directive, maskable interrupts should be disabled by a call to rtems.interrupt_disable and will be enabled when this directive returns to the caller.
NOTES:
This directive will not cause the calling task to be preempted.
