OAR
RTEMS 4.5.0 On-Line Library
Interrupt Manager Directives
6.4: Directives
  • Interrupt Manager INTERRUPT_CATCH - Establish an ISR
  • Interrupt Manager INTERRUPT_DISABLE - Disable Interrupts
  • Interrupt Manager INTERRUPT_ENABLE - Enable Interrupts
  • Interrupt Manager INTERRUPT_FLASH - Flash Interrupts
  • Interrupt Manager INTERRUPT_IS_IN_PROGRESS - Is an ISR in Progress
  • This section details the interrupt manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
