Getting Started with GNAT/RTEMS
If any of the following commands produce output, then you have environment variables overriding the default behavior of the native GNAT toolset. These variables will conflict with the cross toolset. Please resolve this problem before proceeding further.
echo $GCC_EXEC_PREFIX echo $ADA_INCLUDE_PATH echo $ADA_OBJECTS_PATH echo $LD_RUN_PATH echo $C_INCLUDE_PATH
