RTEMS Logo
RTEMS 4.10.1 On-Line Library
Native Hello World Test
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
2.1.1.1: Native Hello World Test
Place the following Ada source code in hello.adb:
with Text_IO; use Text_IO;
procedure Hello is
begin
   Put_Line ( "Hello World");
end Hello;
Use the following command sequence to ompile and execute the above program:
gnatmake hello
./hello
If the message Hello World is printed, then the native installation of GNAT operates well enough to proceed.
