RTEMS Logo
RTEMS 4.10.1 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.8: RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_reset_statistics(
  rtems_id  id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period initiated successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
DESCRIPTION:
This directive resets the statistics information associated with this rate monotonic period instance.
NOTES:
This directive will not cause the running task to be preempted.
