RTEMS Logo
RTEMS 4.10.1 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.7: RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_get_statistics(
  rtems_id                                id,
  rtems_rate_monotonic_period_statistics *statistics
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period initiated successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
RTEMS_INVALID_ADDRESS - invalid address of statistics
DESCRIPTION:
This directive returns statistics information associated with the rate monotonic period id in the following data structure:
typedef struct {
  uint32_t     count;
  uint32_t     missed_count;
  #ifdef RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS
    struct timespec min_cpu_time;
    struct timespec max_cpu_time;
    struct timespec total_cpu_time;
  #else
    uint32_t  min_cpu_time;
    uint32_t  max_cpu_time;
    uint32_t  total_cpu_time;
  #endif
  #ifdef RTEMS_ENABLE_NANOSECOND_RATE_MONOTONIC_STATISTICS
    struct timespec min_wall_time;
    struct timespec max_wall_time;
    struct timespec total_wall_time;
  #else
    uint32_t  min_wall_time;
    uint32_t  max_wall_time;
    uint32_t  total_wall_time;
  #endif
}  rtems_rate_monotonic_period_statistics;
This directive returns the current statistics information for the period instance assocaited with id. The information returned is indicated by the structure above.
NOTES:
This directive will not cause the running task to be preempted.
