RTEMS Logo
RTEMS 4.10.1 On-Line Library
Partition Manager PARTITION_RETURN_BUFFER - Return buffer to a partition
PREV UP NEXT Bookshelf RTEMS C User's Guide
13.4.5: PARTITION_RETURN_BUFFER - Return buffer to a partition
CALLING SEQUENCE:
rtems_status_code rtems_partition_return_buffer(
  rtems_id  id,
  void     *buffer
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - buffer returned successfully
RTEMS_INVALID_ADDRESS - buffer is NULL
RTEMS_INVALID_ID - invalid partition id
RTEMS_INVALID_ADDRESS - buffer address not in partition
DESCRIPTION:
This directive returns the buffer specified by buffer to the partition specified by id.
NOTES:
This directive will not cause the running task to be preempted.
Returning a buffer to a global partition which does not reside on the local node will generate a request telling the remote node to return the buffer to the specified partition.
Returning a buffer multiple times is an error. It will corrupt the internal state of the partition.
