RTEMS Logo
RTEMS 4.10.1 On-Line Library
Partition Manager PARTITION_GET_BUFFER - Get buffer from a partition
PREV UP NEXT Bookshelf RTEMS C User's Guide
13.4.4: PARTITION_GET_BUFFER - Get buffer from a partition
CALLING SEQUENCE:
rtems_status_code rtems_partition_get_buffer(
  rtems_id   id,
  void     **buffer
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - buffer obtained successfully
RTEMS_INVALID_ADDRESS - buffer is NULL
RTEMS_INVALID_ID - invalid partition id
RTEMS_UNSATISFIED - all buffers are allocated
DESCRIPTION:
This directive allows a buffer to be obtained from the partition specified in id. The address of the allocated buffer is returned in buffer.
NOTES:
This directive will not cause the running task to be preempted.
All buffers begin on a four byte boundary.
A task cannot wait on a buffer to become available.
Getting a buffer from a global partition which does not reside on the local node will generate a request telling the remote node to allocate a buffer from the specified partition.
