RTEMS Logo
RTEMS 4.10.1 On-Line Library
Chains Get the First Node
28.4.14: Get the First Node
CALLING SEQUENCE:
RETURNS
Returns a pointer a node. If a node was removed, then a pointer to that node is returned. If the chain was empty, then NULL is returned.
DESCRIPTION:
This function removes the first node from the chain and returns a pointer to that node. If the chain is empty, then NULL is returned.
NOTES:
Interrupts are disabled while obtaining the node to ensure the atomicity of the operation.
Use rtems.chain_get_unprotected() to avoid disabling of interrupts.
