RTEMS Logo
RTEMS 4.10.1 On-Line Library
Chains Extract a Node
28.4.13: Extract a Node
CALLING SEQUENCE:
RETURNS
Returns nothing.
DESCRIPTION:
This routine extracts the node from the chain on which it resides.
NOTES:
Interrupts are disabled while extracting the node to ensure the atomicity of the operation.
Use rtems.chain_extract_unprotected() to avoid disabling of interrupts.
