RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_ID_GET_NODE - Obtain Node from Id
27.4.7: OBJECT_ID_GET_NODE - Obtain Node from Id
CALLING SEQUENCE:
procedure Object_Id_Get_Node(
   ID   : in     RTEMS.ID;
   Node :    out RTEMS.Unsigned32
DIRECTIVE STATUS CODES
Returns the node portion of the object Id.
DESCRIPTION:
This directive returns the node portion of the provided object id.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id provided.
