RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_ID_GET_CLASS - Obtain Class from Id
27.4.6: OBJECT_ID_GET_CLASS - Obtain Class from Id
CALLING SEQUENCE:
procedure Object_Id_Get_Class(
   ID        : in     RTEMS.ID;
   The_Class :    out RTEMS.Unsigned32
DIRECTIVE STATUS CODES
Returns the class portion of the object Id.
DESCRIPTION:
This directive returns the class portion of the provided object id.
NOTES:
This directive is strictly local and does not impact task scheduling.
This directive does NOT validate the id provided.
