RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services OBJECT_GET_CLASSIC_NAME - Lookup name from id
27.4.2: OBJECT_GET_CLASSIC_NAME - Lookup name from id
CALLING SEQUENCE:
procedure Object_Get_Classic_Name(
   ID     : in     RTEMS.ID;
   Name   :    out RTEMS.Name;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES
RTEMS.SUCCESSFUL - name looked up successfully
RTEMS.INVALID_ADDRESS - invalid name pointer
RTEMS.INVALID_ID - invalid object id
DESCRIPTION:
This service looks up the name for the object id specified and, if found, places the result in *name.
NOTES:
This directive is strictly local and does not impact task scheduling.
