RTEMS Logo
RTEMS 4.10.1 On-Line Library
Object Services BUILD_NAME - Build object name from characters
27.4.1: BUILD_NAME - Build object name from characters
CALLING SEQUENCE:
procedure Build_Name(
   c1   : in     RTEMS.Unsigned8;
   c2   : in     RTEMS.Unsigned8;
   c3   : in     RTEMS.Unsigned8;
   c4   : in     RTEMS.Unsigned8;
   Name :    out RTEMS.Name
DIRECTIVE STATUS CODES
Returns a name constructed from the four characters.
DESCRIPTION:
This service takes the four characters provided as arguments and constructs a thirty-two bit object name with c1 in the most significant byte and c4 in the least significant byte.
NOTES:
This directive is strictly local and does not impact task scheduling.
