RTEMS Logo
RTEMS 4.10.1 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
19.4.9: RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
CALLING SEQUENCE:
procedure Rate_Monotonic_Reset_All_Statistics;
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive resets the statistics information associated with all rate monotonic period instances.
NOTES:
This directive will not cause the running task to be preempted.
