RTEMS Logo
RTEMS 4.10.1 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
19.4.8: RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
CALLING SEQUENCE:
procedure Rate_Monotonic_Reset_Statistics (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - period initiated successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
DESCRIPTION:
This directive resets the statistics information associated with this rate monotonic period instance.
NOTES:
This directive will not cause the running task to be preempted.
