RTEMS Logo
RTEMS 4.10.0 On-Line Library
GDB with PowerPC Instruction Simulator
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
6.5: GDB with PowerPC Instruction Simulator
Make the Build Directory
Create a build directory for the SIS Debugger
cd tools
mkdir build-ppc
Configure for the Build
Configure the GNU Debugger for the PowerPC Instruction Simulator (PSIM):
cd tools/build-ppc
../gdb-4.17/configure \
      --target=powerpc-unknown-eabi \
      --program-prefix=powerpc-rtems- \
      --enable-sim-powerpc \
      --enable-sim-timebase \
      --enable-sim-inline \
      --enable-sim-hardware \
      --enable-targets=all \
      --prefix=<INSTALL_POINT_FOR_PPC>
Where <INSTALL_POINT_FOR_PPC> is a unique location where the gdb with PSIM will be created.
Make the Debugger
From tools/build-ppc execute the following command sequence:
make all install
NOTE: The make utility used should be GNU make.
