RTEMS 4.10.0 On-Line Library
Building the GNU Debugger
Getting Started with GNAT/RTEMS
Chapter 6: Building the GNU Debugger
GDB is not currently RTEMS aware. The following configurations have been
successfully used with RTEMS applications:
- Sparc Instruction Simulator (SIS)
- PowerPC Instruction Simulator (PSIM)
- DINK32
Other configurations of gdb have successfully been used by RTEMS users
but are not documented here.
