A chain is anchored with a control object. Chain control provide the user with access to the nodes on the chain. The control is head of the node.
Control
first ------------------------>
permanent_null <--------------- NODE
last ------------------------->
The implementation does not require special checks for manipulating
the first and last nodes on the chain. To accomplish this the
rtems_chain_control structure is treated as two
overlapping rtems_chain_node structures. The
permanent head of the chain overlays a node structure on the first and
permanent_null fields. The permanent_tail of the chain
overlays a node structure on the permanent_null and last
elements of the structure.
