RTEMS Logo
RTEMS 4.10.0 On-Line Library
Chains Nodes
PREV UP NEXT Bookshelf RTEMS C User's Guide
28.2.1: Nodes
A chain is made up from nodes that orginate from a chain control object. A node is of type rtems_chain_node. The node is designed to be part of a user data structure and a cast is used to move from the node address to the user data structure address. For example:
typedef struct foo
  rtems_chain_node node;
  int              bar;
} foo;
creates a type foo that can be placed on a chain. To get the foo structure from the list you perform the following:
foo* get_foo(rtems_chain_control* control)
  return (foo*) rtems_chain_get(control);
The node is placed at the start of the user's structure to allow the node address on the chain to be easly cast to the user's structure address.
