RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.10: RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
CALLING SEQUENCE:
void rtems_rate_monotonic_report_statistics(void);
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive prints a report on all active periods which have executed at least one period. The following is an example of the output generated by this directive.
   ID      OWNER   PERIODS  MISSED    CPU TIME    WALL TIME
                                    MIN/MAX/AVG  MIN/MAX/AVG
0x42010001  TA1       502     0       0/1/0.99    0/0/0.00
0x42010002  TA2       502     0       0/1/0.99    0/0/0.00
0x42010003  TA3       501     0       0/1/0.99    0/0/0.00
0x42010004  TA4       501     0       0/1/0.99    0/0/0.00
0x42010005  TA5        10     0       0/1/0.90    0/0/0.00
NOTES:
This directive will not cause the running task to be preempted.
