RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
RTEMS C User's Guide
19.4.9: RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
CALLING SEQUENCE:
void rtems_rate_monotonic_reset_all_statistics(void);
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive resets the statistics information associated with
all rate monotonic period instances.
NOTES:
This directive will not cause the running task to be preempted.
