rtems_status_code rtems_rate_monotonic_get_statistics( rtems_id id, rtems_rate_monotonic_period_statistics *statistics );
RTEMS_SUCCESSFUL - period initiated successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
RTEMS_INVALID_ADDRESS - invalid address of statistics
This directive returns statistics information associated with the rate monotonic period id in the following data structure:
typedef struct {
uint32_t count;
uint32_t missed_count;
#ifdef RTEMS_ENABLE_NANOSECOND_CPU_USAGE_STATISTICS
struct timespec min_cpu_time;
struct timespec max_cpu_time;
struct timespec total_cpu_time;
#else
uint32_t min_cpu_time;
uint32_t max_cpu_time;
uint32_t total_cpu_time;
#endif
#ifdef RTEMS_ENABLE_NANOSECOND_RATE_MONOTONIC_STATISTICS
struct timespec min_wall_time;
struct timespec max_wall_time;
struct timespec total_wall_time;
#else
uint32_t min_wall_time;
uint32_t max_wall_time;
uint32_t total_wall_time;
#endif
} rtems_rate_monotonic_period_statistics;
This directive returns the current statistics information for
the period instance assocaited with id. The information
returned is indicated by the structure above.
This directive will not cause the running task to be preempted.
