RTEMS Logo
RTEMS 4.10.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_GET_STATUS - Obtain status from a period
PREV UP NEXT Bookshelf RTEMS C User's Guide
19.4.6: RATE_MONOTONIC_GET_STATUS - Obtain status from a period
CALLING SEQUENCE:
rtems_status_code rtems_rate_monotonic_get_status(
  rtems_id                            id,
  rtems_rate_monotonic_period_status *status
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - period initiated successfully
RTEMS_INVALID_ID - invalid rate monotonic period id
RTEMS_INVALID_ADDRESS - invalid address of status
DESCRIPTION:
This directive returns status information associated with the rate monotonic period id in the following data structure:
typedef struct {
  rtems_id                              owner;
  rtems_rate_monotonic_period_states    state;
  rtems_rate_monotonic_period_time_t    since_last_period;
  rtems_thread_cpu_usage_t              executed_since_last_period;
}  rtems_rate_monotonic_period_status;
A configure time option can be used to select whether the time information is given in ticks or seconds and nanoseconds. The default is seconds and nanoseconds. If the period's state is RATE_MONOTONIC_INACTIVE, both time values will be set to 0. Otherwise, both time values will contain time information since the last invocation of the rtems_rate_monotonic_period directive. More specifically, the (ticks_)since_last_period value contains the elapsed time which has occurred since the last invocation of the rtems_rate_monotonic_period directive and the (ticks_)executed_since_last_period contains how much processor time the owning task has consumed since the invocation of the rtems_rate_monotonic_period directive.
NOTES:
This directive will not cause the running task to be preempted.
