RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager Resetting a Timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.3.6: Resetting a Timer
The rtems_timer_reset directive is used to restore an interval timer initiated by a previous invocation of rtems_timer_fire_after or rtems_timer_server_fire_after to its original interval length. If the timer has not been used or the last usage of this timer was by the rtems_timer_fire_when or rtems_timer_server_fire_when directive, then an error is returned. The timer service routine is not changed or fired by this directive.
