RTEMS Logo
RTEMS 4.10.0 On-Line Library
Timer Manager Canceling a Timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.3.5: Canceling a Timer
The rtems_timer_cancel directive is used to halt the specified timer. Once canceled, the timer service routine will not fire unless the timer is reinitiated. The timer can be reinitiated using the rtems_timer_reset, rtems_timer_fire_after, and rtems_timer_fire_when directives.
