RTEMS Logo
RTEMS 4.10.0 On-Line Library
Interrupt Manager INTERRUPT_ENABLE - Enable Interrupts
PREV UP NEXT Bookshelf RTEMS C User's Guide
6.4.3: INTERRUPT_ENABLE - Enable Interrupts
CALLING SEQUENCE:
void rtems_interrupt_enable(
  rtems_interrupt_level  level
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive enables maskable interrupts to the level which was returned by a previous call to rtems_interrupt_disable. Immediately prior to invoking this directive, maskable interrupts should be disabled by a call to rtems_interrupt_disable and will be enabled when this directive returns to the caller.
NOTES:
This directive will not cause the calling task to be preempted.
