RTEMS Logo
RTEMS 4.10.0 On-Line Library
Interrupt Manager INTERRUPT_DISABLE - Disable Interrupts
PREV UP NEXT Bookshelf RTEMS C User's Guide
6.4.2: INTERRUPT_DISABLE - Disable Interrupts
CALLING SEQUENCE:
void rtems_interrupt_disable(
  rtems_interrupt_level  level
/* this is implemented as a macro and sets level as a side-effect */
DIRECTIVE STATUS CODES:
NONE
DESCRIPTION:
This directive disables all maskable interrupts and returns the previous level. A later invocation of the rtems_interrupt_enable directive should be used to restore the interrupt level.
NOTES:
This directive will not cause the calling task to be preempted.
This directive is implemented as a macro which modifies the level parameter.
