RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager ITERATE_OVER_ALL_THREADS - Iterate Over Tasks
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.16: ITERATE_OVER_ALL_THREADS - Iterate Over Tasks
CALLING SEQUENCE:
typedef void (*rtems_per_thread_routine)(
  Thread_Control *the_thread
void rtems_iterate_over_all_threads(
  rtems_per_thread_routine routine
DIRECTIVE STATUS CODES: NONE
DESCRIPTION:
This directive iterates over all of the existant threads in the system and invokes routine on each of them. The user should be careful in accessing the contents of the_thread.
This routine is intended for use in diagnostic utilities and is not intented for routine use in an operational system.
NOTES:
There is NO protection while this routine is called. Thus it is possible that the_thread could be deleted while this is operating. By not having protection, the user is free to invoke support routines from the C Library which require semaphores for data structures.
