RTEMS Logo
RTEMS 4.10.0 On-Line Library
Task Manager TASK_WAKE_WHEN - Wake up when specified
PREV UP NEXT Bookshelf RTEMS C User's Guide
5.4.15: TASK_WAKE_WHEN - Wake up when specified
CALLING SEQUENCE:
rtems_status_code rtems_task_wake_when(
  rtems_time_of_day *time_buffer
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - awakened at date/time successfully
RTEMS_INVALID_ADDRESS - time_buffer is NULL
RTEMS_INVALID_TIME_OF_DAY - invalid time buffer
RTEMS_NOT_DEFINED - system date and time is not set
DESCRIPTION:
This directive blocks a task until the date and time specified in time_buffer. At the requested date and time, the calling task will be unblocked and made ready to execute.
NOTES:
The ticks portion of time_buffer structure is ignored. The timing granularity of this directive is a second.
A clock tick is required to support the functionality of this directive.
