RTEMS Logo
RTEMS 4.10.0 On-Line Library
Key Concepts Object Names
PREV UP NEXT Bookshelf RTEMS C User's Guide
2.2.1: Object Names
An object name is an unsigned thirty-two bit entity associated with the object by the user. The data type rtems_name is used to store object names.
Although not required by RTEMS, object names are often composed of four ASCII characters which help identify that object. For example, a task which causes a light to blink might be called "LITE". The rtems_build_name routine is provided to build an object name from four ASCII characters. The following example illustrates this:
rtems_object_name my_name;
my_name = rtems_build_name( 'L', 'I', 'T', 'E' );
However, it is not required that the application use ASCII characters to build object names. For example, if an application requires one-hundred tasks, it would be difficult to assign meaningful ASCII names to each task. A more convenient approach would be to name them the binary values one through one-hundred, respectively.
RTEMS provides a helper routine, rtems_object_get_name, which can be used to obtain the name of any RTEMS object using just its ID. This routine attempts to convert the name into a printable string.
The following example illustrates the use of this method to print an object name:
#include <rtems/bspIo.h>
void print_name(rtems_id id)
  char  buffer[10];   /* name assumed to be 10 characters or less */
  char *result;
  result = rtems_object_get_name( id, sizeof(buffer), buffer );
  printk( "ID=0x%08x name=%s\n", id, ((result) ? result : "no name") );
