RTEMS Logo
RTEMS 4.10.0 On-Line Library
Key Concepts Objects
PREV UP NEXT Bookshelf RTEMS C User's Guide
2.2: Objects
  • Key Concepts Object Names
  • Key Concepts Object IDs
  • Key Concepts Object ID Description
  • RTEMS provides directives which can be used to dynamically create, delete, and manipulate a set of predefined object types. These types include tasks, message queues, semaphores, memory regions, memory partitions, timers, ports, and rate monotonic periods. The object-oriented nature of RTEMS encourages the creation of modular applications built upon re-usable "building block" routines.
    All objects are created on the local node as required by the application and have an RTEMS assigned ID. All objects have a user-assigned name. Although a relationship exists between an object's name and its RTEMS assigned ID, the name and ID are not identical. Object names are completely arbitrary and selected by the user as a meaningful "tag" which may commonly reflect the object's use in the application. Conversely, object IDs are designed to facilitate efficient object manipulation by the executive.
