RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_GET_API_CLASS_NAME - Obtain Class Name
27.4.15: OBJECT_GET_API_CLASS_NAME - Obtain Class Name
CALLING SEQUENCE:
procedure Object_Get_API_Class_Name(
   The_API   : in     RTEMS.Unsigned32;
   The_Class : in     RTEMS.Unsigned32;
DIRECTIVE STATUS CODES
If the_api is not valid, the string "BAD API" is returned.
If the_class is not valid, the string "BAD CLASS" is returned.
If successful, this service returns a pointer to a string containing the name of the specified the_api/the_class pair.
DESCRIPTION:
This service returns the name of the object class indicated by the specified the_api and the_class.
NOTES:
This directive is strictly local and does not impact task scheduling.
The string returned is from constant space. Do not modify or free it.
