procedure Object_Get_API_Name( API : in RTEMS.Unsigned32; Name : out String );
If api is not valid, the string "BAD API" is returned.
If successful, this service returns a pointer to a string
containing the name of the specified api.
This service returns the name of the specified api.
This directive is strictly local and does not impact task scheduling.
The string returned is from constant space. Do not modify or free it.
