RTEMS Logo
RTEMS 4.10.0 On-Line Library
Object Services OBJECT_GET_NAME - Obtain object name as string
27.4.3: OBJECT_GET_NAME - Obtain object name as string
CALLING SEQUENCE:
procedure Object_Get_Name(
   ID     : in     RTEMS.ID;
   Name   :    out RTEMS.Name;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES
Returns a pointer to the name if successful or NULL otherwise.
DESCRIPTION:
This service looks up the name of the object specified by id and places it in the memory pointed to by name. Every attempt is made to return name as a printable string even if the object has the Classic API thirty-two bit style name.
NOTES:
This directive is strictly local and does not impact task scheduling.
