procedure Object_Get_Classic_Name( ID : in RTEMS.ID; Name : out RTEMS.Name; Result : out RTEMS.Status_Codes );
RTEMS.SUCCESSFUL - name looked up successfully
RTEMS.INVALID_ADDRESS - invalid name pointer
RTEMS.INVALID_ID - invalid object id
This service looks up the name for the object id specified
and, if found, places the result in *name.
This directive is strictly local and does not impact task scheduling.
